Discuss adhesive in grout line aaaaaaaahhhhhh in the UK Tiling Forum area at TilersForums.com.
mat25
hi any one have any tips on gettin set adhesive out of the grout line have used sp radid floor adhesive cheers:mad2:
Grace'sDad
This is probably a daft idea and will get shot down:stupid: but I use a sharp chisel to carefully scrape at 45degrees to the edge of each tile. I find this removes enough and cleanly enough to then grout. Must be careful not to damage the tile. Seems to work well enough with ceramics but easily cuts into travertine and soft stone.
H
Holohana
piece of wood i use sometimes, cut to size. Strong enough to get addy out but wont damage tiles!
scottish tiler
aye a wee scraper or a plain screwdirver duz the job u can use a chisel aswell or a stanly blade if you dont have any of those, its not anything complicated and should take u about 2 mins if its only a small floor
N
ndwyrain
i use a scraper carefully, or the groute rake, again, carefully.
i know this maybe pissing on your chips, cos its obviously set with you.
but i have a little snipped in half cable tie that is just the right size to run through all grout lines whilst it still soft.
obviously i`m only a novice, and i`m probably gonna get told how useless i am now.lol.
GazTech
rapid set if left to dry for two hours can be easy removed with Stanley & Henry ......Gaz
Reply to adhesive in grout line aaaaaaaahhhhhh in the UK Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
