Discuss A little advice please - wall prep before split face tiling in the The Welcome Forum area at TilersForums.com.
G
giveitago
Hi all,
I have a load of split face tiles to go into a kitchen wall. I took off the old ceramic ones which have been there since the 60s i think. The cement stuff they were put on with isn't steaming or scraping off, it's pretty solid. I don't think it's adhesive as such. I'm wondering if I can just sbr it and put on new tiles or should I get stuck in and try to get it back to the sand and cement underneath.?
Any advice gratefully received.
Dumbo
To be honest I wouldn't put split face tiles into a situation where hygiene and easy cleaning is a must . Not the answer you are looking for but very relevant I feel .
Time's Ran Out
Only you can tell how well adhered the old adhesive is.
As far as the split faced tiles go it’s all about aesthetics.
As it’s a kitchen wall but not described as in front of a cooker or sink there are brick slips and rustic tiles used, and once sealed they can be cleaned.
G
giveitago
Thanks for the advice. I should have mentioned that it's my own kitchen and I'm a keen DIYer.
The wall is at opposite side of room to cooker, hob and sink, more of a breakfast bar wall. I will consider cleaning and hygiene implications however before proceeding.
I think the cement is solid tho - so If i did decide to go ahead , would I be OK to apply them over the cement - is that something that tiler's do if it is solid enough ?
G
GoneGuy
It all depends how lumpy the adhesive is that is left on the wall?
Would it be easier to overboard with a cement board to take the weight of the splitface tiles
Lou
Admin
1,473
Staffordshire
Welcome! What have you decided?
G
giveitago
I'm thinking overboard would be safest solution. I've looked at a couple and the only downside seems to be losing a (little (12mm)) bit of room space. The split face tiles are kind of heavy - don't know exactly but perhaps 30Kg/m2 or so - so that would remove the guesswork. It would be easier to fit them too without am uneven surface. I'm looking at Hardiebacker 500 as a solution - up to 100kg/m2! That's mechanical fixings and glue.
GAZ5518
558
EPSOM
I think the what you are describing is 'sand and cement'.. Which is how tiles were fixed before the introduction of Ready mix and powdered adhesives.
With a bolster and hammer you can get behind it and chop it off( wear gloves)!... Failing that if it's as stuck as you say ... Bond / fill in the gaps and Tile away..( A Tiler would probably fill in and fix at the same time using a flexible powder adhesive)... Good luck .
G
giveitago
It's not too bumpy. I have attached a picture. I used an SDS tile chisel to to get the tiles off and could attack the cement with that, but would rather not!
Reply to A little advice please - wall prep before split face tiling in the The Welcome Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that...
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
