Discuss 77mm between concrete and existing tile floor in the Canada Tile Advice area at TilersForums.com.
j45p41
Hi,
we've been victim to an AWOL builder who has not left enough space for us to insulate with 50mm pir board, screed and then tile.
I was thinking 50mm PIR board over concerete, chipboard and then no more ply.
Should I self level the concrete, assuming the concrete is level but just bumpy or would the PIR board form a level enough base?
Could I just use no more ply on top or should I use a layer of notched chipboard? Thanks!
J Sid
Is the 50mm board because of building regards?
Is there damp course membrane under concrete slab?
Dumbo
As @JulianSidney is there a Dpm,
I would consider liquid dpm that is specific to tiling , so one that can deal with a low build up on top , level over then stick 50 mm insulation boards on top followed by 20mm boards unless you can get 70mm boards .
You may need to check this against building regs to check that the insulation values are up to spec.
If you want to tile don't make a floating floor it will fail .
Ajax123
Hi,
Is 50mm pir critical. If you could reduce this to 40mm using a better performing insulation underpaid perhaps with thermofoil you could then put 35mm of Gypsol rapide screed on top.
j45p41
Thank you for your help.
Yes PIR is due to building regs and there is a DPM below concrete but I was going to add another on top before PIR anyway, given that I will be using chipboard.
Hi Yes, 50mm is required. We had to haggle and get it reduced from 75mm.
So at the moment i go 5mm over what I need, if only there was a way of getting chipboard that I could lay tiles on directly.... :)
Dumbo
Don't use chipboard if you can avoid , you will thank us in the long run , in fact do not under any circumstances make it into a floating chipboard floor if you want to tile it .
j45p41
Here is a possible solution - anybody used DITRA?
mm
Allowance
70​
PIR Insulation
50​
chipboard
22​
Schluter DITRA Matting
3​
tile depth
5​
Overshoot
-10​
Still got the 10mm overshoot though :)
Reply to 77mm between concrete and existing tile floor in the Canada Tile Advice area at TilersForums.com
Hello all, After years of abuse, the bathroom needed an overhaul from top to bottom. Out...
Hi, We are tiling our kitchen with limestone tiles - we have already done it in the hallway and...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
Teejay
