Discuss 20mm brick slips on 12mm ply in the Canada Tile Advice area at TilersForums.com.
Bond
518
Highland
I would be confident enough to do it,( no problem) it’s up to the OP.
He said changing or over boarding is not an option.
Bond
518
Highland
If done correctly, there should not be any problems.
In March of this year, done a job with random stone slips ( up to 30 mm thick) on a feature, behind a free standing log burning stove. Was a bit apprehensive initially, however it worked , a that was with open joints ( without grout or pointing).
Jamorgan90
If you use SBR and water at 50/50 there should be no issues with flexiable cement based adhesive over ply. Most failures occur due to inadequate preparation. Remember the ‘p, prior planning and preparation prevents **** poor performance.
Would you recommend using tile masters prime grip first then ?
P
Perry
You fix brick slips for a living? I have seen jobs that have been there for 20 years and no problems on ply. I have also seen jobs done by the same builders after a day on ply and the slips are on the floor. if its in your house and they are not likely to hurt anyone if they fall off. It may be worth the risk 90% if the ply has been fixed correct you will get away with it. I fix them in shops etc so if they fell on someone I would be sued for alot of money. Also I find it hard to see that the ply couldn't be removed. look at this link.
river-island | - https://www.brickit.biz/projects/river-island-2/
Bond
518
Highland
Sorry don’t have any experience of that product.you could check with there tech people. Also give the ply a good key, l used 40 grit sandpaper, and a rub over with damp sponge, before applying the SBR.
Jamorgan90
I have fitted thousand of m2 of brickslips for many shops. Pret , body shop and miller & carter. Mostly onto plywood and haven't had a problem but I am always looking for new and better ways
One Day
The issue is the ply these days is rubbish and seems contaminated with oil, wax or something which prevents cement keying like it used to. There are flooring grade plys now, but they are rare and expensive.
Seems like a good idea to sand,wipe and prime but really isn't it faster and safer to just overboard with 6mm of something more suitable?
Ply just isn't what is used to be...
Reply to 20mm brick slips on 12mm ply in the Canada Tile Advice area at TilersForums.com
