Discuss 20mm brick slips on 12mm ply in the Canada Tile Advice area at TilersForums.com.
Jamorgan90
hi all,
Looking for some advice. Tiling 20mm thick brick slips onto 12mm ply wood on the walls. It is fixed very well. I am just wondering what prep people would do and what adhesive you would use. Changing the ply for plasterboard or hardi is not a option.
Ply is not suitable these days. Everywhere I look I see failures involving ply.
Save yourself the risk and overboard it with 6mm wedi board or similar. (even dare I say it - 6mm hardibacker)
Bond
518
Highland
If your sticking with the ply, a flexiable cement based adhesive, prime well and apply slurry or burn a tight coat of flexi adhesive on to ply . Before applying slips.
L
LM
Why do something that is more than likely to fail?
Either replace or over board the ply.
Bond
518
Highland
If you use SBR and water at 50/50 there should be no issues with flexiable cement based adhesive over ply. Most failures occur due to inadequate preparation. Remember the ‘p, prior planning and preparation prevents **** poor performance.
Reply to 20mm brick slips on 12mm ply in the Canada Tile Advice area at TilersForums.com
