Uneven Concrete Base Before Tiling Worth Fixing or Work Around?
Hey everyone,
I’m getting ready to install tile on a small patio area and ran into a bit of a hiccup. The existing concrete base has a few low spots not huge dips, but enough that it might mess with the tile leveling.
A concrete contractor I worked with before (he helped me with a driveway fix) once mentioned that slight unevenness can be corrected without tearing out the whole slab, but I didn’t ask him much about it at the time.
I’m just wondering if I should use a leveling compound to fix these spots before tiling, or if it’s something I can deal with while laying the tile? I’d rather not get too deep into it unless I have to.
Thanks for any suggestions!
Hey everyone,
I also received lot of help from these professionals: https://www.concretecontractorsannarbormichigan.com/concrete-flooring-finishes-ann-arbor-mi/
After cleaning the surface, I noticed a few small uneven areas nothing major, but enough to make me wonder if they might throw off the tile leveling once I start laying them down. Has anyone run into this before?
Hey everyone,
The adhesive should not exceed depths given by manufactures instructions
DIY Tiling Forum
Tags Tags
None
CoraJentry,
Kastar UK,
CoraJentry,
Kastar UK,
