Discuss Paramount Wall fix in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Paramount wall fix for tiling ideas? the plan is (or was) to tile floor to ceiling with 200mm x 100mm x 7.5mm ceramic tiles. As you can see the wall has seen better days, I appreciate and ideas for making the wall good for tiling. My thoughts for what its worth are....
1) channel out cardboard and plasterboard to fit stud work/noggins (there is a wood batten top/bottom and both ends of the wall already) then fix tile board to stud ( would this benefit from marine ply then the tile board?
2) As per 1) but fit stud/ply/tile board in front of plaster, less work but lose space.
3) Screw/glue marine ply in front of wall then tileboard?
Your suggestions please....
Many thanks
Richard
pink
Many thanks
Richard View attachment 114048 View attachment 114049
stud with 4x2 and make new wall you said you have top bottom stud and put tile board over top with insulation
in wall
Reply to Paramount Wall fix in the Canada area at TilersForums.com
Apatel
