Discuss Slight chipping on porcelain tile in the Canada Tile Advice area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
It’s best to clean the joints as you tile. Can you replace the chipped tile. ?First time tiling and when removing the levelling spacers I tried to remove some addy from the surface and slightly chipped the surface. What do you guys use to cover, still need to grout also.
I was cleaning the joints but the tile leveller had raised the adhesive which i had not noticed, i cant replace the tile unfortunately, its not the biggest of chips, just wondered if some infill would do the trick.It’s best to clean the joints as you tile. Can you replace the chipped tile. ?
Reply to Slight chipping on porcelain tile in the Canada Tile Advice area at TilersForums.com
