Discuss Shower/ Wetroom waterproofing in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
H573
You might be better off going straight on to the level 2 diploma I teach the level 1 it's just basic & you re-visit some of the level 1 on the level 2 anyway
Thanks Andy, that’s really helpful, much appreciated. I’ll take your advice and try and get straight on the level 2
worse case scenario you have to do the level 1 which you can do in 2/3 months then move on to the level 2 , you'll just have to put a little more graft in H
H573
Cheers Andy, How long approximately does the level 2 take?
I’m more than happy to put the graft in.
I left school with no qualifications. I was a window cleaner 25 years and hated every minute of it. I love tiling it gives me a great sense of satisfaction.
H573
Sika products seem to be available but to be honest you'll probably be a trail blazer tanking a shower over there much like it is here in Spain.
Thanks PDC. I think you’re right you mention tanking and waterproofing for showers, even primers and nobody knows what you’re on about. And availability is non existent.
Like Spain pretty much everywhere is tiled here.
WetSaw
..and probably the same as here, tiling is done before plastering ( if anything is plastered rather than rendered) so you're going straight on to block/brick. Very rare to find a house here with any plasterboard walls.
on 3 days a week the course should take 24 weeks ,but as you a maybe a gentleman of older yrs like myself, the college may only be able to offer you 18 weeks again it's how you apply yourself to the course ,put also remember like myself they only cover the basic to get you started on your journey into tiling.Another thing like PDC said to you half hour ago & you replied there could be an opening into the supply market for what you are about to embark on also Good luck
H573
Yep, same here. Plasterboard is available but no one uses it. And customers just won’t pay for it. They render everything internally and externally, and yes more often than not they tile straight onto block work.
Italy
Thanks for the reply, substrate is concrete on the floor. The walls are block covered with what they call plaster here but it’s just sand and cement. Some local products are tilefix, tuffstuff but it’s just adhesive and grout they sell. Can get some SA products, TAL, Progrip but not waterproofing kits etc just bonding agents, adhesive and grout.
It’s a single story property so ground floor, they don’t have timber floors here just a concrete foundation and they tile straight onto it, no primer or anything even on walls!!!
you don't need primer if it's all sand and cement.
H573
Thanks Andy. Take care mate
H573
Hi Antonio,
I know this is from a long time ago.
I can’t get primer, my substrate is just sand and cement. Do I just brush/ vacuum then tile. Or do I have to dampen the sand and cement first then tile?
Italy
Hi Antonio,
you can also moisten ...
Reply to Shower/ Wetroom waterproofing in the Tanking and Wetrooms Forum area at TilersForums.com
mcgtech
