Discuss Which dry disc for 115m grinder. in the Canada Tile Advice area at TilersForums.com.
Italy
I’ve got a few different blades, montolit dna, premtool and a few from ats.
It all depends on what material you are cutting as some blades are better for ceramic than porcelain
one for all is quite adel ....
I used to think like you before,
I have changed my mind a few months ago, one is enough.
but I miss the test with thin porcelain :)
258
Surrey
With these blades running dry, can you still get a neat cut on the angles for a wet room former or is there slight chip out on the edge?
Reply to Which dry disc for 115m grinder. in the Canada Tile Advice area at TilersForums.com
  • Poll
