Those blobs onto emulsion...
Give one of the tiles a bit of a tug and, well....
You'll see!
You'll see!
Discuss Builders Tiling job - is this acceptable? in the Canada Tile Advice area at TilersForums.com.
In a word, NO.Hi, I'm having my bathroom renovated and would really appreciate some advice as I've heard/read conflicting information and would like to know where I stand. The job is due to finish around the of this week.
The tiles are 600x300mm and 9mm thick porcelain.
Please see the attached image, which is a screenshot of multiple images. I can upload the individual files if you need to see any larger.
Clockwise from top left image:
2755 - adhesive
2543 - Ply back wall and platform for shower. When queried he said it was marine ply so would be ok.
2543 - side wall plastered, cut out for shower niche
2570 - constructed plywood niche sitting on shower tray.
2604 - Tiles being put on top of plywood on wall and on niche
2760 - dot and dab tiling. He agreed it didn't conform to British standards but it was the only way to make it look straight after he plastered the walls.
2762 - 3 piles of 16mm thick adhesive per tile along at least one wall
2768 - adhesive is aprox 60-70mm wide
2659 - tiles being laid on floor
2780 - tiles on plywood
2788 - tiles were laid on top of this wall
Thanks.
I thought it was a sunken bath...lolYou need a step ladder for the shower tray.
Why is it so high?
I'd now ask him to guarantee his work in writing for 5 years, and only under his personal name (which it ultimately would be if he's a sole trader). If he is operating under a limited company, then don't allow a guarantee from his company name, as he could easily just close down the business in the event of a claim and not pay out. If it's under his personal name and address, that will allow you to chase a payout indefinitely through the county and high courts for little expense. If he refuses, then he probably doubts his own work. In that case, ask him to remove it all and start again. If he refuses that, then ask for a refund and take the key off him.Good morning.
Thank you all for your advice.
I’ll give you an update with the timelines:
On monday 15/3/19 I discovered the job was potentially problematic. I arranged for a tiler to come out and check out the work on the tuesday. I then spoke with the company I have doing renovations to my entire property, which includes the bathroom, telling him of the problem and he agreed it didn’t conform to uk standards. I said to concentrate on the other work and I’d get someone in tomorrow to inspect the work and advise on its safety.
That night I returned to the property and discovered he’d ignored my instructions to stop and had all but completed the tiling and covered up the edges where the dot and dab tiling was evident.
On tuesday 16/3/19 I advised the pro tiler I'd asked for input and he said it was a nasty situation and pulled out of visiting, not wanting to get involved. I don’t blame him, I’d love to do the same but its my house.
My property is far from completion and completely uninhabitable. Plus he’s been paid in excess of the current status of renovations.
Not quite sure what to do.
5 year guarantee? Optimistically think 5 months would be long enough in this case anywayI'd now ask him to guarantee his work in writing for 5 years, and only under his personal name (which it ultimately would be if he's a sole trader). If he is operating under a limited company, then don't allow a guarantee from his company name, as he could easily just close down the business in the event of a claim and not pay out. If it's under his personal name and address, that will allow you to chase a payout indefinitely through the county and high courts for little expense. If he refuses, then he probably doubts his own work. In that case, ask him to remove it all and start again. If he refuses that, then ask for a refund and take the key off him.
Reply to Builders Tiling job - is this acceptable? in the Canada Tile Advice area at TilersForums.com
