Discuss Prime old plastered walls in the Canada Tile Advice area at TilersForums.com.
Evening all,
Quick question on priming old walls. Original plaster is in reasonable condition, some minor imperfections etc.
Do i need to prime the walls before tilling old plaster?
Thanks!
Time's Ran Out
What’s on the surface of the plaster - wallpaper , emulsion , paint glue size.....
Will only take 22kg of total weight.
Small downstairs loo. Biggest wall is 1940 x 1220mm Looks like very old paint, possibly from the 1950s. It's not flaky or damaged however. I stripped old wallpaper off and sugar soaped the walls.
Waluigi
Yes you should prime plaster. Usually an acrylic primer. The maximum you can hang off a plastered wall is 20kg PSM Which includes Adhesive and Grout.
Remove paint first.
widler
Knock it off and re board, seriously, for the size of it, it will work out better and no more expensive than bodgeing it
Reply to Prime old plastered walls in the Canada Tile Advice area at TilersForums.com
Hi, I'm trying to assess what prep is needed on the walls for my kitchen backsplash. We'll be...
Hi all, I removed some old tiles from the shower and wanted to know if it's possible to tile...
Morning all, I'm attempting a bit of diy tiling in my kitchen whilst off work. I've pulled off...
Hi, We are redoing our main bathroom and looking for a second opinion on tanking. We have bought...
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
Teejay
