Discuss Tiling onto Ply, can it be a success? in the DIY Tiling Forum area at TilersForums.com.
So ... unfortunately I can't take the Ultimate S2 back.
Apologies misread first sentence, you don’t have to answer obviously, why?
Setaflex will be under £200, you can flog ultimate on ebay if you have to, you can easily recover half your costs of setaflex.
You may even find someone on here who would want it for the right money.
The cost of the failure would be astronomical in comparison.
AD1
It was ordered through a friend who placed a larger order on a house build and so can't return them.
So I'm thinking I will get an S1 adhesive. What S1 would people advise? and do CTD/Topps tiles stock it?
Thanks again.
Do not go to Topps.
Regular CTD users here can advise on a choice from there.
And yes they sell numerous S1 class adhesives.
AD1
Oh, So I can take back the GT1.
What's more flexible/suitable, standard wide joint with GT1 or superflex?
Adam.
Just Rizzle
WHY DO YOU HAVE WOODEN HANDLES ON PANS.
ANSWER BECAUSE WOOD IS AN INSULATOR.
take up all the wood and replace with 2 layers of backer board 90 degrees to each other both adhered to the screed floor and the other to the 1st layer of backerboard. this will allow better heat transference so reducing you soon to be sky high heating bills if you have wood as the layer above your ufh,and also reducing your 100% chance of failure due to the ply or wood.
AD1
The heating has been installed for 1 year already and works perfectly. Heating bills have went down, floors are warm to touch even with laminate flooring. I realise backer board would be better to tile on than ply hence why I am getting advice and hence the title of the thread.
Can someone respond to my previous comment on the correct adhesive from CTD?
I am now going to return the BAL grout for standard wide joint.
Thanks.
J Sid
[QUOTE Can someone respond to my previous comment on the correct adhesive from CTD? [/QUOTE]
I did, see above :D
Reply to Tiling onto Ply, can it be a success? in the DIY Tiling Forum area at TilersForums.com
