Best small tile cutter suggestions/recommendations?
Hi, new on here....couldn't find an answer already on here.
Anyway, I'm looking for a small tile cutter, probably enough to cut 300mm tile, but maybe smaller, to save me lugging round my 650mm cutter when I'm doing metro tiles etc.
I've seen the sigma 37cm one and the montolit 26A2 and also a 8 inch montolit one too!
Thanks for your help.
Thanks guys.
I like the size of the mini 22cm montolit but I'm not sure I'd need the lateral size stop end thing for running 8 or 10 tiles of same size.
Plus I'd need a larger cutter for 300-350mm tiles.....
A4C6DC5F-BA81-4BC6-A7B5-5B185DFBBF0B.jpeg Last metro kitchen I did I used my little Bricollina tile saw for every cut, no mess or water everywhere and cuts very quick and clean. Even pushed 600mm porcelain thru it no probs with the better blade in it.
It’s really really nice. Easy to keep clean too. The only missing thing I think ( unless I have missed it lol ) is an angle degree marker when tilting the table.
You say that but you get a build of gunge inside the blade guard under the table .
On mine the screws for the blade housing have snapped off. Other than that it’s still running good
Paul James Farrell,
Albert,
Paul James Farrell,
Albert,
