Discuss Preston Wetroom Renovation in the Tiling Jobs | Find a Tiler - Post Tiling Work Here area at TilersForums.com.
Status
Not open for further replies.
YT233
208
Preston
A wetroom renovation needs completing. Impey tray has failed. Needs ripping out and replacing with Wedi ligno tray. Tiles need removing on 2 walls boarding up with Wedi and tiling. Wetroom area to be sealed with Wedi.
2 sided glass enclosure to be fitted.
I am looking for a tiler who is experienced in using the Wedi system.
Q
Qwerty
Is it the Impey tray that has failed, the waste trap that has failed or the tanking that has failed?
YT233
208
Preston
The water is dripping from the round ring. Not from the actual waste or the waste connection
Q
Qwerty
The only way that an Impey former can fail is through incorrect tanking technique (not sealing it correctly at perimeter or into trap), failed tanking membrane or no tanking membrane.
What membrane was used and how was it laìd at perimeter and into trap?
YT233
208
Preston
From my understanding and memory, this was about 10 years ago. Everything was tanked and sealed as per impey instructions. The tanking back then was the black sticky stuff. Not the new tilesafe membrane.
Status
Reply to Preston Wetroom Renovation in the Tiling Jobs | Find a Tiler - Post Tiling Work Here area at TilersForums.com
  • Poll
