Independent Tiling Consultant needed
Paying Topps £3000 doesn't mean anything as you probably could have paid a lot less with another tile supplier for the same materials and spend the extra on higher rated professional tiler.
Incidentally, what was your budget for the tile fixing?
"Educational videos on YouTube" don't always educate you in the correct techniques. I very rarely use spacers with mosaic tiles and even when I do it's only to keep the odd tile in place that hasn't been fitted to the backing correctly.
I had received a quote from the builder which included the labour element for tiling, as I paid for the materials. So I don't know what his figure for tiling was. Just like I don't know what he included for a painter, a plasterer and a labourer (for when a couple of walls were removed. Plumber and electricians provided separate quotes to him. I would reckon though, now that he has stated how much he paid to other trades and since I know his normal daily rate, that he had included £ 2,000 for 1 weeks work in tiling.
Youtube is not the bible of tiling.
I don't say it is, however I consider it a reasonable source of information and as it contains a load of experience then I have to give due weight to it. For instance, I could see the consistency of the grout that they used - and I compare it with the consistency of the grout that the contractor used - his grout was too sloppy - and I believe that this has led to a lot of shrinkage on drying and the pitting on the vertical tile trim in the photos.
Mosaic sheets, in their construction, are sometimes misaligned when being formed by the manufacturer - are you going to complain to them too?
But you would never leave them misaligned, would you Tom ?
Any tiler worth his salt would cut the mesh round the offending piece and re aline it.....a common problem that I've no doubt we have all come across..
What if they are paper faced sheets?
At what point do you start taking the hit for straightening out poor quality mosaics or turning around to your customer and telling them you need extra money or walking of the job .
Nick, I feel for you.
However, do you have some pics of the overall bathroom? (I’m sure you have!). Close up pics are fine, but we need to see the overall picture.
I think we can all agree that the quality of the finish is unacceptable. All areas of the work need a good washdown to remove excess grout and grout haze. Some areas need re-grouting. Some areas need grouting. All internal joints need siliconing.
You will need a professional tiler to visit, as the problems may not just be on the surface. Do you know how the builder fixed (stuck down) the tiles? There may be hollow voids under the tiles.
You may be lucky and get a good tiler to come in for a day and sort out these issues.
Have you paid this bloke?
p.s. I know what you mean about the mosaics. They ARE misaligned. This IS the fault of the person who stuck them to the wall.
Nick Jones,
Simon Dale,
Nick Jones,
Simon Dale,
