Discuss Once tiled, how long before turning on ufh in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jas0n
hi,
I’m close now to finishing of the tiling in my kitchen with porcelain tiles. I am looking for some advice on when it would be safe to be able to switch the ufh back on. I have used a Topps Tiles flexible rapid set adhesive but there is no guideline for when to switch the ufh back on after using there product.
Jason
Wait 28 days for adhesive and grouts to cure
Start the ufh at ambient temperature,
approx 15 degrees.
Increase the temperature by no more than 5 degrees a day until max temp is reached.
Leave at running temp for two days and then reduce by same 5 degrees a day until off.
Then you can use the ufh, increasing the temp over a few days.
The ufh heating should never be whacked on full from cold or from hot to Off in one go.
If the heating is likely to be off for a period of time, ie a holiday or summer months, always decrease over a few days.
Thermal shock can be caused at any time, and the most likely cause being a dramatic change in temp, from hot to cold, or vice versa.
Chalker
Thanks Paul, that I didn’t know. :):thumbsup:
Common mistake is that people think the floor should feel hot. It shouldn’t.
45 degrees at the manifold will give a floor temp of around 32 degrees. With timber, or a amtico floors, the temperature should be reduced even more to give a floor temp of max 29 degrees. This can be controlled with a floor probe.
Floor coverings should be considered at the design stage. And pipework design can then accommodate this .
Jas0n
Thanks for the advice, I’m glad I’ve now found this out otherwise I would have turned it on. Looks like I will have to plug in a few rads in the kitchen for the next few weeks then.
As for the blending valve it has been set to max, and I don’t really want to be messing with the manifold and the stuff with it as that’s not something I’m that clued up on.
Reply to Once tiled, how long before turning on ufh in the Tiling on Underfloor Heating area at TilersForums.com
Dawz84
