Discuss Will tiles stick to wood and plastic? in the Canada Tile Advice area at TilersForums.com.
john craddock
About to fix tiles to 7" space between tiled wall and shower tray. The new tiles approx 6 will be sitting on a wood infill and part of the plastic coated shower tray. Can i just use tile adhesive on this or do i have to do any preperation? Thanks.
john craddock
Welcome to the forum John, can you post a pic
so that we can see what it is you are asking
P
Paul ja
Is that really a 7" wide strip ? It looks more like 2" - 3"
If it it that narrow what about using UPVC window trim (available in various widths) and silicone it into place
L
Lisa t
About to fix tiles to 7" space between tiled wall and shower tray. The new tiles approx 6 will be sitting on a wood infill and part of the plastic coated shower tray. Can i just use tile adhesive on this or do i have to do any preperation? Hi...how did you do it in the end ? ...i have same query..thanks
Reply to Will tiles stick to wood and plastic? in the Canada Tile Advice area at TilersForums.com
  • Poll
Hi Guys have a big gap above tray to fill 2cm high 1cm deep (3/4in x 1/2in) Any suggestions...
