Currently reading:
Grout coming out and crackling noise under some tiles
Discuss Grout coming out and crackling noise under some tiles in the Tile Adhesive / Grout Advice area at TilersForums.com.
Sachin Parab
Removing laitence from the floor is not just a case of a quick skim over or using a scrapper.
What method did he use and what equipment?
This year I ripped out and refixed an anhydride floor, which I know 100% was sanded by the contractor.
The reason I know is the client made a point of asking what they were doing.
The Builder then continued to install the floor with his Tiler.
9 months later it failed, on inspection, laitence was still present, it failed.
So we had to start from scratch, including re sanding of the floor.
The moisture reading using the hygrometer, how long were they left in place before readings taken?
I think a hand held sander was used. Is there a specific equipment he should have used.
The hygrometer readings were taken in 72 hours.
How do we check if laitance has been completely removed.
You really do need to remove a tile to see what’s beneath.
The cracking sound is where the tile has de bonded from the floor.
It’s important now to determine what has de bonded. The tile from adhesive, or adhesive from floor.
That will narrow down your search for an answer.
The floor need sanding back to expose the aggregates to be 100% sure it’s been removed.
First two images have laitence still remaining on the failed floor, bearing in mind some has already been removed and some was stuck to the tile.
476173A9-B73F-4452-888D-F83A2603C742.jpeg EA4B25A1-E244-4A69-9EF0-BDEE3FB6E257.jpeg 6FDF23EA-2CC3-4BE7-A385-940340FFC425.jpeg 8195F181-CA63-4BBC-9245-A89BDFA1D1F8.jpeg
Enlarging the last image you can see the dark spots, that is the aggregates.
Can be done with a hand grinder but that’s quite an area for a small machine.
More typically a floor sander would be used.
(They look like an industrial cleaners buffing machine) but you would fit abrasive discs instead, around 60# grit.
And you need dust extraction.
You can see the quantity produced.
And priming is critical when using a cementitious adhesive on an anhydride floor.
2 coats is not necessarily enough.
And they should be applied perpendicular to each other.
Sachin Parab
View attachment 94599 View attachment 94600 View attachment 94601 View attachment 94602
Thanks a lot for this. I will speak to the builder accordingly.
Chalker
1,058
Tadcaster
He claims to have done these before and used the same screed and it has worked well
Maybe he hasn't done a floor this big before.
Tiling a large floor has more complications. The main one on underfloor heating is expansion. If there are large areas with form of expansion, like doorways and large single rooms the floor will move and the tiles won't. This can debond the tiles.
As said above the screed should be dry, then it should be abraded to remove the latience. Then vacuumed and primed. 2 coats is a general rule, but it should be primed until it stops soaking in.
Then a flexible adhesive suitable for the screed in question. With good priming, a cement based adhesive can be used. But far better to use an gypsum based adhesive, as that's what the floor is.depending on the size of the are a decoupling membrane should be used. Expansion strips should be installed to help large rooms and in doorways, as different rooms expand at different rates. Tiles should then be fixed with a notched trowel and tiles back buttered.
Not knowing the sizes of the room,I would guess this is an expansion related problem. I would bet your going to remove a tile and agin find the adhesive is stuck to the tile and not the floor.
To sort this, it needs two things.
1. Fitting as above with close attention to movement joints and uncoupling.
2. Get a tiler with experience of large gypsum based floors.
R
Rookery
They're a complete pain in the arse. I've never had a failure myself but have re-done a few where the people before didn't know what to do and so there often were failures. Its always the same things too, too much moisture/laitance not removed/removed wrong time/inadequate priming/etc/etc and they're still not always flat. What's wrong with a sand & cement screed, you know where you are with one of those and if you want it flat, lay it flat. It's interesting that the regular firms I use such as Mapei/BAL/Weber here don't sell a gypsum adhesive. Do they know more than me? Well probably but I'm not going to tile onto anhydrite again. Too many variables. If they want to tile onto anhydrite they can get some other idiot to do it, I don't need it.
Blunt Tool
You really don’t like it do you
Ajax123
1,213
Lincolnshire
Havent read through the entjre thread but was curious...If the builder used lafarge anhydrite screed why has an investigation been started by cemex?
Problem sounds relatively straight forward... screed not dry and no moisture test done 3 weeks is not long enough for drying a screed properly. Im guessing prep was not done correctly either.
Ajax123
1,213
Lincolnshire
Interesting that both Weber and mapei have gypsum based adhesives in mainland Europe though where there's quite a lot ,more anhydrite used. In the UK it is still increasing at a huge rate with this year acheiving something like 3million square meters plus.with increased penetration into all market sectors. A huge proportion of this is tiles without any issues whatsoever. There are many issues with sand cement screed. People dont generally choose their screed based on the fact that numpty tilers dont do the job properly. There are a good many good competent tiles who tile anhydrite screed almost daily and do not have issues. Stop blaming the screed and start looking more closely at what you are doing...
Ajax123
1,213
Lincolnshire
I know perfectly well what I'm doing than you very much. And working on a gypsum floor isn't going to be one of them.
Which is of course your prerogative and your choice. However that is not because anhydrite screeds are bad or tricky or "a complete pain in the wotsit". If they were that bad or that tricky they would not be so incredibly successful and widely used. There are so many really tangible advantages to using gypsum as a screed binder when compared to cement screed in many cases it is a no brainer. What made me laugh most of all was the fact you said you have never had an issue with one yourself and you have been perfectly happy to sort out other tillers **** ups on them... your comments are in conflict with themselves...
The bolts and braces way would of been to put a decoupling membrane down, something like durable c++ after the floor is primed. This let's the floor flex, has a water/moisture barrier and let's a small amount of air under the tiles. Done this many times and, touch wood, never had a problem, even on floors twice this size. My understanding is with most anhydrated screeds is that you don't need any expansion joints under 300m2 unless you see cracking. It's softer than a typical concrete floor so most don't recommend using a cement adhesive but a Gypsum based as the cement based is too strong for the floor. To be honest if you do see cracking, which is quite common, you would use a decoupling membrane anyway.
Ajax123
1,213
Lincolnshire
Maximum single bay size is indeed 300m2 but there should be movement joints at door thresholds, between independently controlled zones and where heated meets unheated. Unfortunately these joints are very often not included. The reason for using gypsum adhesive is to do with chemical compatibility. Gypsum adhesive is actually as strong as cement based in general but the level of shrinkage is much lower.
Reply to Grout coming out and crackling noise under some tiles in the Tile Adhesive / Grout Advice area at TilersForums.com
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
