Discuss Silicone seal shower corners in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
P
Paul ja
Hi
I've just completed a re-tile of the en-suite using Porecelanosa Cubica. the shower area is 3 wall, 2 white on black. I'm struggling to get a decent 'line' of silicone seal on the vertical black to white tile joint using white silicone (dow 785). The white to white doesn't look too bad at all but had to resort to the finger, the fugi tools dont like the tile contours.
I'm thinking of 'trying' to mask the black side with tape
Advice please
Personally I apply silicone then spray with water with some washing up liquid then tool up . It works well for me but you have to be tidy with the application
P
Paul ja
hope this helps
I have used those tiles, but not mixed colours. I don’t think a fugi tool will help you much. A fine well applied bead then some light smoothing will be your best option. Other option is to clear the joint out and use clear silicone
P
Paul ja
I agree the Fugi tool doesn't help. Clear silicone is an option is suppose. Can the silicone be done in two hits, i.e. verticals first and then 24 hrs later the tray ?
Q
Qwerty
Yes you can do verticals and horizontal joints separately. I find that by slowly and neatly applying your coloured silicone into the joint, and then smoothing out with a soapy finger (washing up liquid solution) works best. Fugis have thier limitations and that type of tile is one of them!
P
Paul ja
That's the method I've tried and it wasn't good enough so I fetched it all out before it dried. I just haven't got the years of experience to do it right first time !!
Might think longer about doing the verticals in clear - thanks
P
Paul ja
Having had a practice on tile off cuts I think I'm going to go with clear. No matter how I try with the white I can't get an edge on the black that I'm happy with ! The best edge I've achieved with white was using masking tape and then a final wet finger when the tape was removed. I think the only way white would work is if you could lay a run down and not touch it i.e. The nozzle does the work.
John Benton
I've recently done a bathroom with same tile, although the Cubica was only jointed within the niches. Rest of bathroom was split with a darker tile. However, I don't use white on Cubica I use a 'Snow White' by Ottoseal which matches the shading perfectly. I used masking tape and found it was fine.
P
Paul ja
Very nice job there, I would say my white to white joints are very similar.
I will try masking the black making the final finger pass before removing the tape, this will leave a small lip but hopefully it will be a straight edge.
Bond
If you leave the masking tape in position until the silicone has gone off, you can with a straight edge and Stanley knife achieve a crisp straight edge.
P
Paul ja
I'll have a practice run at doing this on a couple of off cuts - thanks
Reply to Silicone seal shower corners in the Tanking and Wetrooms Forum area at TilersForums.com
mcgtech
