Discuss 1mm cut off disc other uses in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
As long as you don't have high expectations.So it passes for as it says a multi purpose blade.
It does what it says on the tin!.
Well this is where your 'fit for purpose' statement comes in isn't it.You wouldn't necessarily have high expectations from a multi purpose blade, however they have there place. They are not claiming to be a high end product.
Even marcrist do a cut it all blade. Page 29 cut any thing.As long as you don't have high expectations.
Personally, I use a different blade for every material type.
Experience has shown me that if you use a blade on porcelain and then on a subsequent project use the same blade on stone, the next time you use it on porcelain, it won't cut with the same high level of finish. Swapping between materials with the same blade only impedes its performance.
Ergo....a multi purpose blade, will never have a high level of finish on any material, just a passable one.
Reply to 1mm cut off disc other uses in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
