Discuss 1mm cut off disc other uses in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Italy
I just hope you do not talk seriously.
otherwise you have to keep it open
the hospital doors ..
and then explain to your insurance,
how did you do.
best wishes to all those who want to try.
Albert
1,253
Gateshead NE8, UK
As long as you don't have high expectations. :)
Personally, I use a different blade for every material type.
Experience has shown me that if you use a blade on porcelain and then on a subsequent project use the same blade on stone, the next time you use it on porcelain, it won't cut with the same high level of finish. Swapping between materials with the same blade only impedes its performance.
Ergo....a multi purpose blade, will never have a high level of finish on any material, just a passable one.
Even marcrist do a cut it all blade. Page 29 cut any thing.
http://www.partscenter.co.uk/wcssto...hRes/std.lang.all/hu/re/Marcrist_Brochure.pdf.
Blunt Tool
IMG_1014.JPG Page 29
Reply to 1mm cut off disc other uses in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
  • Poll
