Discuss Never used a grinder to cut tiles... in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Yes either flip the tile over and trim it from the back or as i often do just hold the tile stood up and take the last bit out, it's a bit easier to see what's happening that way. When I say wet sponge I don't mean damp I mean really quite wet
I cut those limestone tiles dry....dose this mean the blades knackered..?
No Andy, not at all mate.
You can dress the blade if it starts to dull.
You can buy proper dressing stones or use a piece of stone which is fairly hard but not dense.
The diamonds get clogged and buried under the metal of the blade, so you need to expose them again and it will rejuvenate your blade.
You're just trying to clear away the debris left behind.
This will tell you all about it if you're interested Andy
Dressing stone
Italy
Dressing stone
the dressing,
Do NOT use on blades or drill bits, Brazed Diamond.
Example, like that posted by local.
Keeping a rounded corner is all good for a lot of floor applications but around windows when trimming etc it's not great
No it's not I'll agree Andy, but if your straight cut meets the radius of the hole perfectly then it can give a perfectly good result.
Its far more important for floors than walls Andy, there are not the stresses place on walls that there are floors, although-that notwithstanding, if you're tiling on to studded walls it can be just as important to reduce the risk of corner tiles breaking.
Especially if timber hasn't been dried or acclimatised properly, soon as it dries out it shrinks and can cause corners to go.
In fact I've seen it recently, a unit was tiled around in a stud wall of the bathroom and both corners went after just a few weeks.
It's just about minimising risk,you can do no more mate.
Kyle Knowles
1,108
Widnes
This whole wet sponge thing has me thinking about rigging up a garden spray bottle the kind u pump up for preasure and a length of silicone tide the kind u use in a fishtank air stone set up and drilling a hole in the guard of the grinder
Kyle, that so last year! Haha
Yeah already tried that, needs tweaking tho, not as straight forward as it seems unfortunately. Problems arise with keeping the operator safe from electrocution :D
Montolit have it cracked for about £600 I think.
Reply to Never used a grinder to cut tiles... in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
