Discuss Tilers spirit levels?? in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Just for you Andy @Localtiler,
There are some reflections because of shower glass and highly polished rad, but it'll give you an idea of how it works.
If you look carefully the main cross hairs follow the joint vertical and horizontal.
The weird image is the line going up and over ceiling, and the long shot down corridor, if you expand you'll see the vertical line in the door jamb.
So last placed in one location it covers all surfaces. No separate wall or floor laser.
And tbh if you buy good quality separate items, the multibeam is just a bit more than the two put together.
H
hmtiling
after a quick charge and mess around the only negative(very slight) is it doesn't have a fine tune for vertical beam like my dw089k did. the positives are everything else!
H
hmtiling
to add to this it doesn't swivel super easily like the dw089k which makes fine adjustments easier
J Sid
so do any of these level manufactures make them with the bubble you can adjust to get it spot on after it starts reading wrong? They used to
A
A williams
&& everything is online if you look hard enough I'm sure you'll find one!!
Pendulum on the laser we use so it gets it right every time :)
Reply to Tilers spirit levels?? in the Tile Tools | any Country any make any model area at TilersForums.com
Apatel
