Discuss Help finding similar tile in the Free Discontinued Tile Finding Service area at TilersForums.com.
Dan
Admin
1,318
Staffordshire, UK
I doubt you're going to find it easy to find those to be honest. You could try taking a picture into a Topps Tiles store. They used to do a tile-finding services. But it'd be a case of them needing to know the name for them to enter it into their systems. They sometimes have the odd tile a few years old in their stores somewhere across the country and can bring it up by name. But I'm not sure 11+ years they'd even have the same staff in the store now that they had when that tile was on the market. Worth a chance though perhaps.
40+ is a fair area. Can you perhaps section it off and use another contrasting tile and make it look like it was meant to be like that? Do you have a picture of the full area that has the damaged or missing ones? We can perhaps come up with some ideas for you...?
38
Coventry
This is a photo of the area I need to patch up. I had a new window put in so I need to patch it up somehow.
40 tiles is a overestimate. I found some similar tiles but they're 200 x 200. The original tiles are 200 x 250. I don't know whether the 200 x 200 will be sufficient.
268
Wiltshire
Could you possibly strip them off as a column ceiling to floor and replace with a 200x250 white... giving a "band" effect (as a bigger chunk it will make it into a feature instead of a bodge block).
Reply to Help finding similar tile in the Free Discontinued Tile Finding Service area at TilersForums.com
  • Poll
Hi Guys have a big gap above tray to fill 2cm high 1cm deep (3/4in x 1/2in) Any suggestions...
