Discuss Grout removal from 2mm porcelain tiles in the Tile Adhesive / Grout Advice area at TilersForums.com.
llevram
288
London
Hello all, what would people suggest is the best way to remove the grout in an en suite shower enclosure?
The tiles are Matt finish 600mm x 300mm and have grey grout. I'm looking to remove the grout and replace with white.
Any help or suggestions would be very welcome.
Thanks in advance
That's the one to use. Remeber this though - shake it up, and then shake it some more.
Then when you've shaken it - shake it again.
and again
and again....
you get the idea?
It settles in the bottle easily and the pigments can stay in the base of the bottle.
Shake it like you mean it!
llevram
288
London
and again
and again....
you get the idea?
Hahaha shake it like a Polaroid picture
Reply to Grout removal from 2mm porcelain tiles in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Poll
