Grout Ultra Grout
Mine wasn't fibred just to 10mm depth but it was on a sovereign 2 part resin floor which had been primed with Neroprene primer from the same company.
Do you still use it? I've never tried the level it 2 but can get it very cheap. Does it flow well?
It does flow really well only upto 10mm thick but used a spike roller for the first time to push around and came up so smooth, carpet was going on top but looked good, plumber said it was the smoothest slc he'd ever seen 🙂
You've only seen it micro crack that one time?
It wasn't so much micro cracks, it was a garage that had been transformed into a living room many years ago and had some damp coming through the floor, the reason for the resin coats.
It was very fine cracks at one half of the room which were quite spread around and as said no sound of them being hollow, yes first time but may have been the smoothness of the floor but all done correctly.
No particularly reason I could see why it cracked.
I've just started doing a bit of work for an interior company and they supple the ultra gear, I really like the adhesives but, must say, I remember why I stopped using level it 1 a few years ago, it's a terrible product, it doesn't flow at all well and has hair line fractures all over it every time. It just seems to be bulked out with sand, there's so much of it in the bottom of the buckets when rinsing them out. I've not used the grout yet, I keep swapping it for grout 3000 🙂 I've got another job for them next week so may give it a test.
Ultra Grout
Grout
Andy Allen,
dynamictiling,
Andy Allen,
dynamictiling,
