Discuss Split Face Tiles in the Canada Tile Advice area at TilersForums.com.
A
Alexb
Hi, I have to lay some split face interlocking tiles in a bathroom. They are supposed to be laid without spacers tight to each other so there will be no grouting. However there bound to be still some small gaps between tiles - how can I make it waterproof?
Also, with the split face tiles surface being uneven, how can I seal the gap between the bath and the tiled wall?
Tile Shop
Can't think of any supplier that would recommend them for that situation.
I'd personally be nervous about putting them in the direct wet areas. Cement based adhesive and back skimming is essential. A couple of heavy coats of sealer (LTP Mattstone or similar) will be needed, whilst tanking every tiled area being the best way to protect and seal the wall and the gap to the bath (with tanking tape to bridge the gap). Regular bead of silicone but it might be harder to apply because of the texture.
But none of this will stop water getting through the gaps of the tiles, into the adhesive, into the back of the tiles etc.... and because its going to take in more water than any other tile, it might cause cracking and splintering in the future and potentially falling off altogether.
However people have ignored advise and done it in the past with no issue, and I'm sure many on here have also done it and will say its ok with immaculate preparation. But I like to be cautious as I've seen the odd horror story with various Splitface tiles in bath and shower rooms. And the last think I'd want whilst playing with my rubber ducky, is a slate tile bludgeoning me in the back of the head.
John Benton
As Andy says, personally would never fit in a wet area, only as a feature wall
A
Alexb
Thanks Paul, very useful.
Thanks Paul, very useful. Will try to get him to change the tiles.
John Benton
And also they will harbour bacteria and mould in all the crevices (crevice, now that's a dirty word) devilishly hard to keep clean, so just tell him that and it should steer him away from the wet area
Lithofin BOB
If you trying to put him off, you might mention - that ideally after each shower he will need to dab towel the tiles before leaving as these tiles will hold water on the face and the ( dirty crevice!!!!!) this can then evaporate and produce a mineral salt , this left to build can be difficult to remove and becomes unsightly very quickly.
A
Alexb
Thanks guys for your help, will definitely try to talk him out of it.
Spare Tool
Had this issue a couple of months ago, customer wanted a strip of split faced slate down the centre of a shower cubicle, talked her out of it and fixed a high level border around the room instead, well out of the way of imminent water damage ;)
A
Alexb
Paul and the guys, I had a chat with the customer today, showed him all the comments on the forum and managed him to change his mind. Thanks all for your help.
Tile Shop
Good choice, but more importantly, a safe choice. There are quite a few realistic looking imitations. Just gotta shop around for them.
Reply to Split Face Tiles in the Canada Tile Advice area at TilersForums.com
  • Poll
