H
hmtiling
Hi all. Looking for a basic tester/meter to be used before a hair hygrometer on anhydrite screeds.
Many thanks.
Many thanks.
Discuss Basic Tester in the Australia Tiling Forum area at TilersForums.com.
Many thanks.
I would like to get a CM tester from karl dahm
Is that one to be used instead of the hygrometer?I would like to get a CM tester from karl dahm
Yes carbide bomb test they call itIs that one to be used instead of the hygrometer?
Doubt it. I don't rate the hygroboxes personally and any testing that I have seen done with them has been suspect in the least. The other thing is you have to leave them in place for several days which means trips back and forth to site. If you want a quick answer (30 minutes) then you'd be better off investing in a carbide bomb kit. You can get these online or via travis perkins. If you need a contact at Travis let me know. They are a bit more expensive but worth it if you are talking about big areas of expensive tiles.Looking at a protimeter hygromaster with a humidity box. Do we think that would do instead of a hygrometer?
@Ajax123
Reply to Basic Tester in the Australia Tiling Forum area at TilersForums.com
