Boothy01
Hi i will move cable if this is problem as tiles are big and got spare but can it be wired bk together thanks
Discuss Warmup Underfloor Not Getting Hot in the Tiling on Underfloor Heating area at TilersForums.com.
I'm surprised the thermostat isn't showing an error, they usually do. Twisting the wire together could still cause a short, it needs to be repaired properly before you can determine if that is your issue.Well moved toilet and tile and yes plumber gone through with a screw i have wired together but still nothing i am just swisting them to see if heats up but nothing any idea cant be wired wrong can it
Stop messing with it you'll end up killing somebody. You can't just twist the ends!Well moved toilet and tile and yes plumber gone through with a screw i have wired together but still nothing i am just swisting them to see if heats up but nothing any idea cant be wired wrong can it
I was involved in a UFH repair and had to uncover some cable for sparks to repair.
This was warmup prowire which has very fine cable, even with the kit the experianced sparky failed dissmaly to make a safe connection!
He had to concede to getting warmup in to make repair. View attachment 78429 View attachment 78430 View attachment 78431
That's not his job that's a repair 3_fall got I think mateWhy is the heating cable on top of the ditra?
Reply to Warmup Underfloor Not Getting Hot in the Tiling on Underfloor Heating area at TilersForums.com
