Discuss Warmup Underfloor Not Getting Hot in the Tiling on Underfloor Heating area at TilersForums.com.
Boothy01
Hi i will move cable if this is problem as tiles are big and got spare but can it be wired bk together thanks
J Sid
Warmup offer a repair service, was a couple of hundred pounds I think. Your plumber should be picking up the bill, if it was him that coursed the problem.
Before your go down that road get a local electrician, again your plumber will have someone he uses, to test the wires first.
Boothy01
Well moved toilet and tile and yes plumber gone through with a screw i have wired together but still nothing i am just swisting them to see if heats up but nothing any idea cant be wired wrong can it
Ian
I'm surprised the thermostat isn't showing an error, they usually do. Twisting the wire together could still cause a short, it needs to be repaired properly before you can determine if that is your issue.
I was involved in a UFH repair and had to uncover some cable for sparks to repair.
This was warmup prowire which has very fine cable, even with the kit the experianced sparky failed dissmaly to make a safe connection!
He had to concede to getting warmup in to make repair. image.jpeg image.jpeg image.jpeg
Dan
Admin
1,318
Staffordshire, UK
Stop messing with it you'll end up killing somebody. You can't just twist the ends!
Boothy01
Thanks sorted ended up getting new matt as some of tiles where broke so replaced the the matt was cheap enough and already had thermostat
AD Ceramics
758
Manchester
Reply to Warmup Underfloor Not Getting Hot in the Tiling on Underfloor Heating area at TilersForums.com
