Re: Help Concerning Silicon
tricky_tiler
After some advice re shower cubicle in the photo. Silicon seal the bottom ... What about the vertical bit? Should I remove grout and Silicon? Or Silicon over the existing grout? Thanks!
Remove grout and Silicon in the corner...and get a grout cleaner while your at it to give the shower sparkle.
Thanks for that.
A lot of the grout appears to be cracking. I have removed quite a bit for the left wall, haven't started on th me right wall yet. If I plan on regrouting it , how much grout do I need to remove first? Thanks again!
The reason for all of this is because of a slight damp patch appearing in the toilet directly beneath the shower!
Thanks for your help so far! Especially at nearly midnight!
Just looked at your profile.. clay pigeon shooter eh? Any good?
I would scrape the Silicon out from where the shower tray meets the tiles and as said the corner and re-Silicon, this maybe only a temporary measure, where your grout is cracking on the tiles you need to remove to the depth of the tile.
There is usually a reason that the grout is cracking, moisture getting into the substrate or if a tubbed adhesive was used causing it to expand or soften up and allowing the tiles some movement.
A re-tile will be probably needed in the near future but as always that would be your choice.
Tubbed adhesive & grout no good then? That's what I have just brought to redo the grout!
I haven't been shooting in ages!
I would go for one of the Mapei Ultra colour not in white though, Tilemaster grout and many others that available for regrouting.
Neither have I concerning the shooting, one ground wants .40p a clay on a sunday....jeeeeeve
Off to bed.. Thanks for the advice - I'll be back with more questions and updates on my shower!!
Tiles/grout look manky.
Is a full rip out not on the cards?
Just got my first gun cabinet last weekend.........next is the licence??
Manky? Are you referring to the bits where I have removed the grout??
The rest could could do with a good scrub/clean but I wouldn't call it manky.
Money & time don't warrant a full rip out.
Is it a shotgun certificate your getting? :thumbsup:
get on the real deal lads 🙂 ...as mentioned previous, scrape out existing grout, re-grout using a "proper" grout, silicon all corners including vertical and and shower tray 🙂
finished job looks soo much better. Less manky. :smilewinkgrin:
And yes.......it is a shotgun cert next. Watch out them clays. :thumbsup:
get your *** up here Col, forget the tin pot, not very realistic, even flying clays...real birds are the true test,,,oh, and bring some cider (proper cider) with you. [MENTION=42242]Tricky[/MENTION] tiler, that looks a helluva lot better 🙂
get your *** up here Col, forget the tin pot, not very realistic, even flying clays...real birds are the true test,,,oh, and bring some cider (proper cider) with you. @Tricky tiler, that looks a helluva lot better 🙂
I shot shot a sparrow with an air gun when I was a young-en........I felt guilty as hell. I couldn't shoot anything alive now.
Well, maybe the French. :smilewinkgrin:
Try a few grey squirrels, they don't like it up em:83:
tricky_tiler,
White Room,
tricky_tiler,
White Room,
