Discuss New Big Clinker cracking tiles in the UK Tiling Forum area at TilersForums.com.
Bathfix Bob
588
Some of you may remember I was looking for a manual tile cutter and after much pondering I bought a big clinker, I used it for the first time today and was very happy with it but it did crack 2 or 3 tiles upon 'breaking'.
The tiles were nothing big just ceramic of roughly A4 size, they all cracked while cutting on the longer length and I was just scoring once and pulling down gently.
Does anyone know why this happend? I had loads of successful cuts though from it.
DHTiling
You are breaking to close to the tile edge.. pull it forwards to about 50mm in and try again..
White Room
So many different variables, if it was just a couple of tiles I would'nt be to concerned, if it was 50% then I would be concerned.
Bathfix Bob
588
Thanks I'll try moving it up tomorrow, I wouldn't care but every crack was on the half I wanted!
It does save loads of time over the machine cutter though.
Bathfix Bob
588
I may be wrong but I don't think this machine allows you to break further down, the wheel gets in the way.
I've left it at the job so I cant check.
DHTiling
Ahh right, then try not to apply to much pressure on the break.. just a light tap..
Slowly Learning
I had the exact same problem last week. Always cracked on the left hand side of the tile so just measured up so the piece I wanted was on the right hand side of the cutting line. Never done it before and hasnt done it since, may need a new cutting wheel to ensure good clean cut as they dont last as long as a rubi wheel. Dont rush out and buy a new cutter just keep an eye on it and see what occurs mate.
tfs
I tiled an adapted wetroom with cheap ceramics and many of the tiles broke so scored with big clinker and snapped over my knee or over edge or thin dowel. I never experienced this on any other tiles so put it down to the tile. A few weeks after this I was speaking with a tiler down at the tile shop who had the same experience with the tiles that I had fitted.
the wheel has three settings that allow you adjust the depth so hopefully shoudn't get it in the way unless the tiles are very thick e.g. 20mm
Bathfix Bob
588
Correct TFS!, I checked the instructions before I logged on and you're right I can adjust the wheel height to allow a mid break
You were right all along Dave!
Reply to New Big Clinker cracking tiles in the UK Tiling Forum area at TilersForums.com
