White Room
Did'nt realise that kind of money was involved, I can see where your coming from now and wish you had mentioned this in your first post it may given different replys to your situation
Discuss Contract of works - what should I put in the UK Tiling Forum area at TilersForums.com.
Fair point mateHi Guys,
Understand where you are coming from with your comments - but as you can see I have been stung once - twice shy as the saying goes. I have already spoken to the tilers about doing a contract of works and they are happy with this.
The reason I have posted this is get your guys help to come up with something that is realistic.
ie - the lippage - I am asking what percentage I would be looking at to be reasonable along with other items.
I just want something down in writing to make sure that both ourselves and the tilers are working towards the same thing with no ambiguity.
For example - saying the reason the tiles are spot fixed is because the walls are out - after the job is nearly finished. Mosaics that are going to be 1cm above the bath meaning we would of had 1cm of grout or sealant down to the unless there was going to be a 6mm tile cut!!
I am sure that something like this would be specified by architects. All I want is a level playing field with all expectations laid out at the beginning.
This is going to cost me in the region of £1500 - £2000 to get the room redone - on top of the £1500 it has cost to get to this point. Plus more than likely me working the next 2 or 3 weekends to get the tiles off the wall and the walls made good again. Time I should be spending with my family seeing as though I am away all week.
we are not picky - just want a good job done - not the possible lethal bodge up that we have now.
I hope you guys understand.
Steve
Just another point : " tiler to check walls for level " ?
As a customer expecting a top class job, surely you should check and be responsible for ensuring that the walls are level prior to tiler commencing. You need to give the guy a fighting chance of doing that perfect job
Hi Leatherface
I know the walls were level before the last tiler started - I done all the prep work! However, nothing was written down - agreed to etc...I need it confirming from them so that cannot be used as an excuse for poor tiling. This is about protecting the tiler as much as me. The tilers have already agreed to come in and do this as well before starting the job - it is just getting it down in writing.
By the way - the tiles are Young Stones from CTD
Steve
Hi Guys
You may remember my last thread on the bathroom bodge-up. Well we appear to have found some new tilers (Finesse of Chester) however, I want to draw up a contract of works so there can be no disagreement in expectations before, during or after.
We are having 600*300 laid landscape in a standard pattern (no brick bond) with two strips of mosaics running horizontally round the room - one high and one low (see pictures in the thread I mentioned above) and two different colours of the tiles - with the light running through the centre and the mosaics bordering the light.
So - what can I put in a contract. So far I have
3. Lippage of Tiles - What should I put for this??
4. Mosaics are to be flush to surface of tiles - no undulation, standing proud or sunk, and no twisted individual Mosaics.
5. Grouting - Grouting is to be either flush to the face of the tiles or no lower than the slight chamfer on the edge of the tiles. What size grout line would be best with these tiles??
10. An on site inspection of a recent comparable job,
Now what else should I put down - Sealing corners? straightness of tiles - looking to you guys to help me avoid another disaster and need to get this to them by next weekend.
Cheers
Steve
Might sound a silly question but where are you from
if your new tiler has agreed to a written contract then there should be no problem i understand that youre taking pre cautions due previous experience but i have to agree if a client came to me with a written contract then id be inclined to walk away as it could be more hassel than its worth but i do understand the money you have pay out.
anyway good luck hopefully second time lucky
Reply to Contract of works - what should I put in the UK Tiling Forum area at TilersForums.com
