When things go WRONG: Why we get called out to jobs to rescue clients with bodge job
Deleted member 1779
Example of when THINGS GO WRONG:
Case study:
Client uses a general builder for a loft conversion. By the time we arrived on site there was a lot of trauma and finger pointing.
The builder quotes to do all the work himself. What we see is a "basic" job gutting out then plaster boarding the loft. He completes First fix electrics, plumbing, plastering and door furniture, paints etc.
The builder has done a reasonable job. But many angles were off, work is "ok" but not perfect.
Biggest mistake the builder made was not to subcontract the tiling to a pro. The client has purchased an expensive top end selection of porcelain tiles and glass inserts. But although the builder is a jack of all trades he has never dealt with these materials before so wings it. He soon runs into all sorts of problems fitting it.
Even so his work is not looking too bad huh!
His Second fix is coming along nicely.
But lets look closer.... To get to this point in tiling the builder had broken about 2 x boxes of glass tiles and porcelain tiles when he tried to "drill" the service pipes.
Above you can see he used an angle grinder used to "hack" the tiles. from the back. The problem is that the hack over-bored the holes so the capping plates do not cover the mess. He even planned the tiles to "fall" into the four corners to make the waste pipe easy to grind. Thats time wasting and not really necessary with the availability of large 40mm diamond drills. If only he knew they were out there..
His second error is that when trying to drill small holes for example for the shower rail he tried to cheat and use the grout line. But all this managed to do was split the glass tile. Arrgggg... And to cap it all off his masonry drills were burning out on the porcelain tiles.
At this point the builder gave up and walked off the job.... Client very distressed at losing so many expensive tiles and faced with taking out this damaged tile.
The client gets onto the internet and finds 365Drills. When we arrived at the site the first thing we do is managed to convince the client we can save the tile. Saving it reduces the time on the job removing it, new adhesive, new grout and costs to the client are minimised.
We ground out the glass with an 8mm core
The Result (above). YES you can still see the split glass. Yes its ugly. But as luck would have it the broken piece can be covered with the capping plate as part of the shower rail. The glass had not split too deeply.
Moving on: This next hole looks much better! This is one we started from fresh. PORSADRILL diamond core drills (size 8mm used) can grind out the glass tile and you can see that its a perfect barrel.
This result is really strong and will take a rawl plug and the fitting without splitting the glass.
NEXT:
We then went on to finish drilling all the holes for the job to include
  • Wash basin screws (16mm) plugs
  • Shower screen rails
  • Mirrors
The drill plate is so adaptable and flexible that when we came up against this preinstalled (and glued) shower door rail, rather than remove the rail to drill the hole, we cut a piece of the guide plate so that the 8mm guide was ultra close to the edge of the strip. It was just less hassle to cut a bit off than it was to undo the whole contraption.
SUM UP:
Tiles are becoming more sophisticated. A general builder might be able to wing it when dealing with a lot of the construction stuff. Most of it is common sense.
But clients should be aware that they pay (in time and money) for any areas the builder is not competent in.
If the builder had been aware of Porsadrill I am confident he would have saved the cost of those broken tiles when he installed service pipes. He would have saved the embarrassment of splitting a fitted glass tile. He would have saved his own time plus he would not have walked from the job for something so trivial.
Re: When things go WRONG: Why we get called out to jobs to rescue clients with bodge
Nice one Rich :hurray:
In my line of day-job work, I cannot possibly know everything there is to know about the intricasies and detail, so I always speak to someone who does know these things before I make a decision or respond to something.
Just a little bit of reflection and forward thinking can stop a lot of things going completely wrong.
:thumbsup:
Well 'saved' richard', must remember to 'refresh' my set next month.
WTF !!! I can't believe the mistakes the builder made. I'm no professional but have been tiling for a few years and have always used 365Drills when needed. I have found that 365Drills are the best for drilling Porcelain, Glass, Stone and any other tile I have laid. I thought an angle grinder was for cutting steel or stone :yikes: not tiles
Well Done for turning a half decent job in to a professional looking job.. :thumbsup:
Neil.Col
:thumbsup: Superhero :smilewinkgrin:
Yup.... Makes you wonder!
This is what the soil pipe looks like with the capping plate ON.
The cap is pushed right up to the tile and that is a so called "Finish"
Lots of other mistakes but I thought I would keep them focused on the tiling errors...
knight in shining armour:24🙁soz about the pooh!)
Oh its all done for Love.....
Well almost love..
i have been using tileasy drill bits lately, mostly 6mm for red plugs. Cant beat them for price & wear.
whats the idea behind the yellow plate
Deleted member 1779,
