Discuss What is the height limit before I have to mechanically fix tiles in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
PlasterboardAnd with those sizes what’s the substrate?
Solid wallsAnd behind the board?
It’s inside tiling I will be putting fixings in the plasterboard into the block work as it’s only dot and dabbed onto block work at the moment I see the tiles he’s ordering today they are actually ceramic there’s only 4m2 above 3metres highIs it inside or out Josh?
I believe mechanical fixing in domestic situation is currently under review.
commercial is 3m and above.
your substrate should be mechanically fixed too.
10mm porcelain is right on limit of Pb. 1or 2kgs to spare. For safety reasons they’d be better off moving up to a backer board.
How you going to mechanically fix the tiles?
Few tubs of green star mate that’s all I’ve got... that’s a joke I’ve got two pallets of bio gel on the job this wall was only decided today he wants to tile it I’m currently doing 11 wetrooms here just found raimondi mechanical fixings so doing some research on them😁 well I’m not gonna tell you what you want to hear Josh.
I’m afraid mate,that’s down to you.
We can assume tho, that you’re not using a dispersion adhesive are you?
Nice, plenty of pics to come then. 😊I’m currently doing 11 wetrooms here
Yes mate lots to do thereNice, plenty of pics to come then. 😊
Reply to What is the height limit before I have to mechanically fix tiles in the Canada area at TilersForums.com
