Discuss Wedi board in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
One Day
Think there's a cartridge glue for fixing the boards,seats etc together
Wedi 610 it's called. Not for sticking boards to floors, rather it's used for joining boards. The principle is - stick blue to blue (the foam core) and it's a waterproof joint.
F
Flintstone
I can see the benefit of screwing after, it's not gonna compress the board and squash the adhesive about and cause dips. Do you crack on with walking on it and tiling it before the adhesive has set ?
F
Flintstone
I must admit, I've recently stuck no more ply down with s1 and screws onto some floorboard rooms due to particularly in even and rough flooring and it does feel
More solid than using there glue
Stef
I use 6mm jacko boards (almost the same as Wedi) on top of caberdeck flooring, the benefit being is they will slightly decouple from the substrate because of the core of the board.
Reply to Wedi board in the Canada area at TilersForums.com
Lowpaul22
