roberto1490
i tiled my wet room tray with small mosaic tiles. trouble is i used an 8mm notched trowel and now realise i should have used a 3/4mm. the adhesive i used is mapei keraquick in white. some of the adhesive came through the gaps in areas so i wiped the surface down. is this going to be a problem? the grout will be the same colour as the adhesive
