Discuss Tuscan Levelling System in the UK Tiling Forum area at TilersForums.com.
smurf5599
Hi all,
Just about to start tiling my kitchen and found this site :hurray:
I always struggle to level tiles and noticed the Tuscan system reviews , now I know for tradesmen that are tiling all the time it may not be worth the additional cost but for me it might be worthwhile.
It looks like you have to buy a huge amount at a time and I wouldn't require that quantity, so has anyone tried the system bought the parts and then decided it wasn't suitable ? If so I'd like to buy the leftovers to give it a go.
Its a pity they don't supply starter kits for the DIYers.
Regards
Melvin
ozboz
Hiya, if you go to a B&Q Warehouse they should have a product for sale that seemingly does the game job as tuscan, they are sort of anchor shaped with a square hole at the top, there are some big yellow wedges in the pack as well, have a look at them they may be an answer to your req'ts, you will find them around the tiling section in black and yellow bags, Tuscan looks ok, but to exxy and a lot of pratting around, anyway ggod luck mate, Setve aka ozboz
Alan.P
1,058
Stockton-on-Tees
Yes B & Q do a similar thing, but they will not help with your levelling problem, all they will do is pull the adjacent lips flush, what tiles are you fixing and can you not just take your time and get them right ?
Welcome to TilersForums as well
smurf5599
Hi Ozboz, thanks for the reply.
I was worried about some of the wedge type systems as they appeared to have a sprung base that put upwards pressure to line up the top of the tile where as the Tuscan system just pulled the tiles together, hope that makes sense ..
I'll check out B&Q and see how it works.
Thanks again.
Melvin
smurf5599
Hi Alan,
I'm using Travertine tiles 600 x 400 , I'm not a tiler and to make it worse I'm very fussy :lol:
I guess it would make it easier once I got going as I'm for ever going back to make minor adjustments that affects the adjacent tiles and it just seems to escalate.
I completely tiled my bathroom last year walls & floor and it took me months , the wife gave me grief about how long it was taking so I'm looking for something to take that particular problem away .. It turned out alright in the end I'll try and post some piccy's.
Regards
Melvin
ozboz
Hi Mate, I take it that on your earlier post when you mentioned leveling, you are trying to eliminate lippage?. if it is .I cant see any harm trying these lash system, and see how you go , it appears to be a fairly inexpensive and possible aid depending on the quality of the travertine you are using there should not be any damage, there is a video on the trade tiler site that shows you how to use this lash system, and recommends them for fixing stone, however, if the substrate is up and down, it would be adviseable to get this flat before fixing, and then have a look at whichway to go, Ok Mate, Steve aka ozboz
Reply to Tuscan Levelling System in the UK Tiling Forum area at TilersForums.com
