Currently reading:
Tling over old tile adhesive
Discuss Tling over old tile adhesive in the Canada Tile Advice area at TilersForums.com.
rich hand
Re: Tling over old adhesive
Make that 15mm min, 150mm could give you issues in the door ways, I would like to see how far Bal would run when you have a failure on T&G floorboards, to quote a firm I respect, "information before a job, = education",
" information after= an excuse".
Wise words. From a very good company with a good work ethic. Please do the job right, think of your client, think of your reputation.
Why be so negative..Information after is learning! And as for the client, he is extremely well educated and certainly understood what he was thinking.
The Legend; Phil Hobson RIP
In what way am I being negative? I can only give advice based on my experience , If people choose to ignore it so be it. Either way it will not cost me one penny, my advice was free.
the cost of replacing the floor won't be. Good luck with it.
rich hand
You haven't read the thread I can tell.
"Information after is an excuse"...what a silly comment after the explanations I have given.
"Good luck with it"...another silly comment. It was the clients experiment as much as mine and it barely cost him a penny.
The client was particularly interested in the adhesive that was used on the London underground to withstand vibration and wanted to give it a go for the sake of 50 quid. Next year the floor gets ripped up whatever happens and he may spend thousands on a new one. He imports materials from all over Europe for such. He knows what he is doing. How many times!!!
The D
So what do you want from us?? Do you want us to applaud your professionalism and marvel at the amazing job you have done using nothing but fastflex and 6mm ply. We can all throw away the BSI5385 as you have proven that it’s all just theoretical rubbish.
If I am honest and I always am if I was in the same situation and the tiling did not have to last and the client was pushing for aquick fix with no come back on me I would slap them down bish bash bosh no problem but I would not have come on a tiling forum and asked if the old adhesive needed removing especially as you are a flooring professional and you already know what the theory is. So my question again is what do you want from us.
Rossymcg
I've read the whole thread and please forgive me as I'm no Sherlock Holmes, however you stated the tiles originally failed because of the addy most definitely not because of movement in the floor, you can't say what addy it is because you don't know, however the owner of the property wants to try out a addy to withstand vibrations from the tube,
No addy designed for the underground would be used on 6mm ply and you've also said that movement wasn't the problem, so how will this experiment stack up?
I'm confused, maybe it's just I'm stupid
Ooooooo toys out of pram, I have read the thread three times.
It made no sense the first time and less the last, why come on a tilers forum and ask questions, get answers, then ignore them.
I will not be gracing this thread with my silly comments anymore.
It ain't worth the effort.:mad2:
Reply to Tling over old tile adhesive in the Canada Tile Advice area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
