Currently reading:
UK Primer G on no more ply - dilution?
Discuss Primer G on no more ply - dilution? in the UK Tiling Forum area at TilersForums.com.
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed).
Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some reason. Why might that be?
What is the correct dilution of primer G to use on no more ply?
The bottle says dilute between 1:1 and 1:3 (primer:water).
What is the purpose / effect of diluting and how does it help the adhesive bond?
Do I need to prime it at all as the tiles might stick better without a layer of primer in between?
Reply to Primer G on no more ply - dilution? in the UK Tiling Forum area at TilersForums.com
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
