Tiling a swimming pool
markc
Just wondered if any one can give me any good tips on tiling a swimming pool with mosaic tiles on sheets. I haven't got the job yet but you never know and preperation is everything :grin:
Basically it's a big extension, just been built 2 months ago with the 7m x 4.5m concrete swimming pool shape all with drains and filter holes ready and waiting for the customers mosaic tiles to go in :whatchutalkingabout
Also non slip tiles to go down on the floor area outside the pool which is 40msq, but this is ok it is just the swimming pool mosaic tiling i am a bit bothered about.
I guess i would set out and start tiling all the pool walls, then the floor. I would be stuck on tiling up to and fitting the drainage grills that go around the pool!!
This might be something that i am getting bothered about for no reason.
Any help would be much appreciated, thank you
nice job there Mark,i hope you get it m8.For mosaic fixing use a 6mm mosaic trowel,white flexi adhesive,white flexi grout.PLACE MOSAICS IN POSITION AND PAD THEM INTO PLACE USING YOUR GROUT FLOAT.Tile walls first then floor.when tiling floor the grills should have like a casing which fits over it so just tile to this same with the lights if there is any.All the best.:thumbsup:
one thing I will say...Make sure that the substrate is spot on because if there are lights in the pool and any of the tiles are kicking out, there will be shadows cast which will look awful...Mark.
Good luck on getting it..
Very helpful, cheers lads :thumbsup:
After another conversation with the customer, i mentioned all the prep work that would be needed along with a qualified Bal/Weber rep to visit the site (Free of charge) to asses all the materials needed! , the customer wasn't interested and just wanted the tiles to go straight in.
So we came to an agreement that i wouldn't do the job. I wouldn't want to do this job with no prep and homework in place, so i'm quite happy on the outcome.
I've just arrived home from another possible job which has a few questions from myself, so i'll put another Q? on later on or in the morning.
Thanks again for the help :hurray:
You did the right thing...it's not always easy to walk away..Mark.
If you are ever in two minds ...follow you gut instincts...it's your best method of protection....Gaz
And if your like gaz and like a Guinness or two then you will know wot your gut instincts are........:grin:
hi mark im a new member also in devon, where u in devon? any idea on where to get good technical information re pool tiling ie drying tmes etc , how to avoid tiles popping later date, as got a pool to do for council?
regards gary
markc,
Deleted member 1779,
markc,
