Discuss tiled wetroom floor in the UK Tiling Forum area at TilersForums.com.
stevie25
tiled a wetroom floor last year tiled the impey tray with small stone mosaics and the rest with 400 square porcelin tiles
the guy called me out some of the porcelin tiles had cracked
i started lifting them and they came up easy and the tiles had no adhesive on them this obviously been the problem
the mosaics on the impey tray are solid
just wondering can give me some advice to why this has happened?
the tiles were onto a ply overlaid floor screwed
floor bonded flexi adhesive &grout used
would appreciate any feedback
many thanks
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
If the adhesive on the substrate doesn't have the imprint from the back of the tile on them when you lifted them, then when fixed; not enough adhesive was used. Which makes sense and the mosaics would have been pushed in a bit more, that's why they'll be solid.
It's a shame that, sound like a bit of a maul.
It could be down to incorrect adhesive type though, and perhaps something else?
Do you have any pictures to hand by chance, that'll explain a thousand words as they say. :)
Daveyboy
Sounds like there are a couple of problems..1 - cracked porcalain tiles would suggest substrate has a lot of movement..would need more info on how they have cracked before recommending a solution..2 - adhesive not bonded to the tiles..could be that adhesive wasn't wet enough to stick to the tiles..tiles too dry/dusty and adhesive couldn't stick to it..sometimes pays to dampen the tiles and/or back butter them before fixing them to the adhesive spread on the floor...
wetdec
Well these guys have covered all the possibles nothing to be said until you give us further imput................:thumbsup:
Reply to tiled wetroom floor in the UK Tiling Forum area at TilersForums.com
