Discuss Tile face up or down when using grinder in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
acaciaguy
Hello all
When using an angle grinder with a tile cutting blade on, do you cut with the tile face up or down.
Do you want to have blade cutting into face ?
Sorry if this is a stupid question.
Time's Ran Out
No such thing as a stupid question ( but it’s close)!
Glaze surface up so your cutting through the glaze and make sure you put the blade in the grinder correctly so it’s cutting in the direction of the arrow.
Now if I’am cutting a hole in the tile I do cut on the back and punch the hole out the front.
acaciaguy
I thought that. Same as cutting into laminate wood etc. What about with porc? Glaze dependent again I guess?
Stupid question number 2 - arrow on grinder matches arrow on blade?
I
Italy
and punch the hole out the front....;(
Waluigi
The arrow on the grinder blade must match with the direction that the grinder spins.
Usually the arrow side out. It is on my grinders/polisher anyway.
acaciaguy
Thank you. I don’t normally have a problem. It’s been a long day and I have been playing with my new disk and cutting guide - which has messed with my head a bit lol. It will all be obvious tomorrow when I look at it again and I will feel like a bit of a ... wally
acaciaguy
My confusion is coming from using a Bosch angle grinder guide / dust extractor. I wanted it to cut straight lines on long tiles. when the grinder is fitted into it the direction arrows are away from the face so looking at it side on the blade spins up not down into face.
Reply to Tile face up or down when using grinder in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
Teejay
