Discuss stained grout & possible solutions to remedy the problem in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
stewp78
Hi there, about a few months ago I retiled the bathroom floor and used a flexible grey grout by granfix, since then small areas ie patches have become quite stained & look wet although I dont think they are wet, I am going to re grout the whole floor. I have used granfix before and had no problems. Could anyone suggest a good floor grout in grey that I could use or would you say that granfix is generally a good product.
Also after doing a bit of research I have come across a product called LTP grout & tile protector, which is a spray that seals the top of your grout & should stop stains, mould , grease etc from appearing. Has anyone used this product, is it any good as i think it may be useful as protection for all grouting jobs whether it be floors or walls.
cheers
Terry Cottar
cheers
Save yourself a lot of hassle and look at other routes first. 1. As Dave says above check that it does not just need cleaning. 2. If that fails you have two more routes prior to regrouting you can use a Aqua Mix Grout Colourant it will cost you around £22 and the floor will be done in an hour or so as you will have already done part one of the process and cleaned the grout or you can use an enhancing sealer such as Aqua Mix Enrich N Seal that will do two things it will darken the grout down to an even colour depending on how many coats you put on and seal the grout at the same time. Good Luck
tel
tfs
Hi mate,
I am a fan of ltp however the grout pretocter realy just adds i little bit of extra protection (not much in my opinion). It can still be penetrated by chemicals, acids and syrups etc. Normal sealers are good enough e.g. glaze protectors and stone sealers.
Reply to stained grout & possible solutions to remedy the problem in the UK Tiling Forum area at TilersForums.com
Apatel
