Discuss Setting out a 4 tile opus pattern in the UK Tiling Forum area at TilersForums.com.
1,073
Poynton, cheshire
I do mine the same as Daz, and Tommy
Mr Tiler
Yes, try to lay out the floor as if you were only using the smallest size tile in your pattern, adjust this to avoid any small cuts,get your lines to start from, and you shouldn't have any small cuts when you use the pattern
everyone agree with this? seems the easiest route to take instead of using the while 4 tile layout but does it work?
Reply to Setting out a 4 tile opus pattern in the UK Tiling Forum area at TilersForums.com
