Discuss Removing rapid set from tile in the Canada Tile Advice area at TilersForums.com.
H
Hlm
Can anyone recommend an easy methods method of removing rapid set adhesive from the back of a porcelain tile?
Can I soak it or does it have to be sanded or ground off?
I
Ian
A grinder is the only way really, it's a painstaking job if you've got a lot of tiles to clean up.
Stef
I used an sds chisel to remove rapid from the back of granite tiles before.
Sat the tiles on a hop up on top of a folded dust sheet.
Removed the adhesive with ease but I thought the tiles would end up shattering, not something I would recommend on a daily basis..
charlie1
Sds with a bit of tlc and you should be ok depending on tile really. Lay tile face down on something soft first. They must be expensive tiles?
charlie1
Ok, while grinder will work, I find it too dusty and if your not used to using grinder then you could be asking for problems as they are by far the most aggressive tool I use. I'd make up a holder for your tiles to cushion the impact. Place tile face down and go gently with sds, you may break a few to start with but you will get the hang of it soon and get the job done. I done about 10m2 using this method a few yrs ago, took me no more than 2 mins per tile (40 x 40)... I will try finding pics
CJ
Thanks for the replies.
Are these disc quick, do they make light work of the addy?
i have have done it myself, but you do have to pad out the face of tile. Didn't break 1 tile.
Do it outside and wear a mask. :thumbsup:
Reply to Removing rapid set from tile in the Canada Tile Advice area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
