Discuss Removing Floor adhesive from polished porcelain in the UK Tiling Forum area at TilersForums.com.
Digger100
just laid the floor and theres adhesive that I need to get off. The floor has yet to be sealed.
Qu: Whats the best way of removing it? I've just tried a damp scourer (green kitchen type thingy) on an off cut and it removed the adhesive quickly and it didn't seem to effect the polished finish on the porcelain at all but will this have a knock on effect when I put the sealant down?
What do some of you wise old heads reckon?
DHTiling
As long as its not fastflex or similar...just wet the adhesive up and then gently rub with a sponge...wash with clean water afterwards and leave to dry .. see how they dry if no residue then seal with porcelain impregnator. if there is residue.. buff tile with a cloth if this doesn't remove it then try lithofin wexa or cement away....clean then when dry seal.....dave..
p.s. if it is fast flex etc...then this will need extra elbow grease....lol lol
GazTech
How much is elbow grease Dave,can you get it from same supplier as self levelling ceiling compound?
Reply to Removing Floor adhesive from polished porcelain in the UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
