Discuss removal of ceramic floor tile sealer in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
L
lee sheldrick
Hi im looking or a liitle help? does any one know how i can remove the sealer off my ceramic kitchen tiles,i need to remove this so i can apply a non- slip polyurethane coating,as this will not stick to the surface with the floor sealent on it.should i remove this or use a sanding method to give it a key ??
Many thanks
Lee..
L
lee sheldrick
Not sure brian or stue, the floor was like this when i moved in,i think its sealed as it is very glossey and my anti-slip coating will not stay on the tiles it peels off so i thought it was sealed??me being a thicko..All i need is some sort of key do you have any ideas??
cheers
Lee
L
lee sheldrick
Sorry camera is out of order at the mo,they are ceramic tiles.
thanks
lee.
DHTiling
What is the none slip you are trying to use..?.. Also if the tiles are contaminated with cleaning agents or small amounts of grime etc then it won't work..
Reply to removal of ceramic floor tile sealer in the America area at TilersForums.com
Apatel
