Discuss Porcelain tile - big scratch repair advice? in the Tile Cleaning and Restoration Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
P
PhilJW
Can anyone advise on this please?
I have off-white matt porcelain floor tiles and one has a long scratch in it.
What is the best way to fill/remove/repair it so that its (as close as I can get) invisible? If any products could be recommended that would be appreciated.
Lastly is has clearly been tried in the past as around the scratch the matt finish has gone and it is now shiny......is there anything I can use to restore the matt finish?
Any help appreciated.
I’d suggest contacting magicman, they have an app you can download and get a quote via this.
They’re specialists in this field.
Don’t raise your hopes too much tho, especially if it’s a plain tile.
Please do come back and show us the results, it’ll be fascinating to see.
Good luck.
P
PhilJW
Good luck.
Thanks - Ill try that.
I
Italy
the kits do not work with scratches.
I tried it with chipping and that's fine.
I removed some scratches on polished porcelain,
with diamond pads and they work,
with matt finishes I do not know how to solve.
P
PhilJW
Here are some photos - the sheen is not too clear as it needs to catch the light but hopefully theres an idea on the last two photos.
Its only about 5cm long but is more apparent than the photos may show.
Its also right in the middle of the floor which is very annoying!
Reply to Porcelain tile - big scratch repair advice? in the Tile Cleaning and Restoration Forum area at TilersForums.com
laattaana
